Scott06
- Joined
- Apr 20, 2014
- 7,620
Yes there is a gasket that will not survive taking apart- oem ones have a rivet in them to ensure continuity between housing and manifold so temp gauge works....I'll take the housing off and double check. Is there a gasket there that needs to be replaced or sealant? Or can I just take it off and put it back on?
What would be the best way to check the impeller output in the water?
You can also pull the hoses off the outlet and look in the ports.
Merc has a flow test you do by taking water supply hose (from outdrive) off the thermostat housing and measure flow into a bucket - X seconds should = Y volume kind of thing. You probably can find it on line or if you have factory manuals it will be in there- cant remember if it is in drive or engine book.
