vroom ZOOM
Thread starter- Joined
- Aug 15, 2017
- 474
I wish it was that easy...it looks as if you are going to have to use the ford part # on the OEM bearings to get the correct bearings .? what colour marking on them.
? has the crank been ground at some stage of its life. or was the crank possibly worn ( measure to see what spec it is)
the reason bearings come in 3 sizes from the factory is because these cranks vary in size ,PIA i know. also people clean up the journal's by nipping / linishing a few thou off.
this is why i posted , measure /compare the ACL race against the ones that come from the motor. its very easy to get it wrong as you have now found..
first of all, ford doesn't sell those bearings separate, they only sell short blocks. Second, the ford markings don't tell me anything, as they don't have colours. There are two size bearings that came out of the old motor, 2 03 R and 1 03 W. I am pretty sure the 2 03 R is the mid size bearing, and after measuring the 1 03 W is an oversize bearing. This would mean that yamaha "red" bearing would be = 2 03 R. Sounds good, but ford doesn't sell bearings. I go to mahle or something and they only have one size... Ugh!
