circlehook
Thread starter- Joined
- Aug 10, 2007
- 67
Do battries have any effect on ignition systems if there marine or non marine types
on ignition systems..... NO.Do battries have any effect on ignition systems if there marine or non marine types
It is not that they wont wirk, they will as you have proved...however the battery life is greatly reduced when not used as they are designed.All I have ever used are deep cell for both house and starting. 2 sailboats with small diesels and 3 motor yachts all with big block gas engines. Never had a problem with starting with deep cells.
Everything I’ve read about the dual purpose…they‘re not great as either starting or deep purpose.
Sources please…. Not my experience at allIt is not that they wont wirk, they will as you have proved...however the battery life is greatly reduced when not used as they are designed.
Using a starting battery as a deep cycle will shorten its life but not necessarily vice versa.It is not that they wont wirk, they will as you have proved...however the battery life is greatly reduced when not used as they are designed.
Deep Cycle Batteries are not designed to repeatedly provide Heavy Current supplies for more than very short periods. I suppose several hooked together in Parallel, would overcome that, then the issue of Equally Charging them configured like that will rear its Head.
I worked for a battery mfgr for a few years, that comes right from the engineers at Johnson Controls battery dept! Just because a few folks have sucess does not mean the majority will. In my 60 years of boating I to have had small sucess using deep cycle batted for starting small engines, but when they get used for big amp draws on larger mtors, they have proven to not last long. The high amp charge rate from an alternator also lessens there life.Sources please…. Not my experience at all
My mother's best friend's husband told me so...I worked for a battery mfgr for a few years, that comes right from the engineers at Johnson Controls battery dept! Just because a few folks have sucess does not mean the majority will. In my 60 years of boating I to have had small sucess using deep cycle batted for starting small engines, but when they get used for big amp draws on larger mtors, they have proven to not last long. The high amp charge rate from an alternator also lessens there life.
At least it is more valid then " because I say so". !!!!My mother's best friend's husband told me so...
I have always used car batteries. BUT, I always have had dual V8s with battery selectors and good alternators. You can drain a marine battery many more times vs a car battery.Do battries have any effect on ignition systems if there marine or non marine types
You are correct….CCA is calculated at 0* F. MCA is calculated at 32* F. MCA rating is 133% of CCA rating.I am not recommending one way or the other but just how many CCA's do you need to start and run a boat during the summer. It's not like I was cranking over the engines at 0* F.
Someone told me they were worth it so I switched. Cars, multiple boats, etc. Then, I found out they weren't. With Autozone wet cell batteries I'm getting 8 years or so. The AGMs gave me less than 6.I’ve used Deka gp 27 dual purpose conventional batteries for years and I usually get 7 years out of them. Thought of going with AGM but not sure if the extra cost is worth it.
