Hoggedfairlane
Thread starter- Joined
- May 2, 2023
- 18
I was told it was a 1997 but clearly it is not as it has the canon plug connector still so it’s 95 or earlierI’m not sure either
I can’t find anywhere it goes and it came from this motor lol
thats green red and blueThat looks familiar ..try the trim and tilt connection on port side of motor
i swapped power head to this one which is older and i have the original control , wiring, and oil tank with gauges. i cant find where that plug goes??The oil tank would have tan/black and black(ground) going to the level sensor.
I suppose that plug could be for a 3 wire VRO alarm set. It would need the purple wire to make it work, along with the alarm logic. See if the tan wire goes to the cylinder head overheat sender.
My '98 has Amphenol and Deutsch connectors, instead of the big red plug.
these pics are from an ocean runner 200i have a 1997 johnson 200 that i purchased for a power head swap.
i have a connector that im trying to find where it goes? am i over looking something?
cdi? stator wires? idk where it goes,
ty for any help..View attachment 378443View attachment 378441
I have an 97 Evinrude 200. I'll look when I get home this evening but going by the wire colors in the manual, the wires are ground, low oil, no oil and overheat.thats green red and blue
thinking its going to oil sensor in tank and alarms but where did it hook on the motor? idk, i bought this with controls and harness and i cant find where it goes lol.
coils are coming weds..lolOk soo i got this motor running
New power pack, stator, trigger, new plugs, cleaned carbs, cleaned fuel tank, took it out of boat, replaced all fuel lines, new plugs,
Runs good on hose, will not run in water, still sounds like it’s losing ignition, sync n link was done also
Bogs off start, through the mid range it cleans up a bit and on top end it has a miss still ??? I’m at a loss
Starboard comp top to bottom
110
110
100
Port is the same
What’s the primary coil to ground supposed to read on my coils?
Secondary is .248
I got cold coming on weds
Any help would be great
Thanks again….
