Viking 25Hp Electric Start
JeffNilson
Apologies, I couldn’t find the proper category to address my issue but I believe this is the most relevant brand to what I have right now. If there is any other way please let me know since I am new here. Can anyone guide me from the attached photos where to find the starter!! If I am not mistaken, the flying wheel is missing and the solenoid as well. Any idea where to find the parts. Many thanks for any help. Jeff
You can remove that ring.----Install a ring with starter teeth.----I have done such a thing.-----Need to find a toothed ring , starter and bracket ( 28 HP to 33 HP Johnson / Evinrude ) from the 1960's only.---Starter solenoid from any Johnson / Evinruse from mid sixties to end of production.-----Or any outboard motor including Japanese motors.-----Possibly a choke solenoid equipped carburetor.-----Your location ?
Looks like motor has overheated ( paint colour ) ,------- So do some inspection.-----Remove bypass cover on intake side to look at piston / rings.
F_R
Go to the parts list at https://richardlpaquette.ca/25D19VPartsCatalogue.PDF to see what the parts look like.
Another site you need to discover is the Antique Outboard Motors Club, www.aomci.org The Ask A Member forum and the Classifieds ads pages will be a big help.
Yes, the parts are common across a wide range of Johnson, Evenrude and Gale motors. (You have a Gale motor)
F_R
There is a Viking Special Interest Group within the outboard club . Richard Paquette, who posted the above parts list is the Viking Group leader. Consider joining the club. The quarterly Antique Outboarder magazine alone is worth more than the dues.
JeffNilson
This is wonderful.. Many, many thanks. At least I can start searching for the parts specially the toothed ring. Appreciate it Racerone buddy. Thanks Jeff
JeffNilson
No doubt you are right, there is a reddish color at the jacket of the upper cylinder. So the bypass part is the one in attached photo below?
F_R
That is the exhaust cover. Intake bypass covers are on the other side.
As for that flywheel, the ring/gear are on the bottom side. That means the flywheel has to be removed to change it----but that is another topic.
I sold and serviced those motors when they were brand new. There is not a single part on them that I haven't had apart at some time or other.Screenshot 2023-05-14 190359.png
