Few wires on yamaha gauge not connected ?
No more boats
Recent purchase working my way thru what's working and not working
Gauge cluster
Tac gauge working , ( not bright )
Speed gauge blank screen ,
discovered ground wiring ,
cleaned reconnected and see zeros ( not bright )
Noticed a number of wires not connected and questing WHY ?
TWO BLUE - one of of each gauge
goes too 4 prong harness , single end off harness , blue, goes too nothing ?
Color chart indicates back light , can this go into red , yellow , green , that have empty cavities or run directly too hot ? or not necessary ?
ALSO - two remaining wires not connected too anything , white off of speed gauge ,
White with blue stripe ,
thanks
blue is for dash lighting
lighting wiring is usually separate. use google to find your gauge and find the documentation that goes for it.
boscoe99
Have you any idea as to the model of the motor or the type of gauges that you have?
Might look something like this:
No more boats
sorry meant too indicate ,
OX 66
250 HP
can the blue go into red cavity that is open , for what ever reason blue is buried in harness with no connector ?
thanks
boscoe99
Blue is for the lights. Red is battery power. I would not think that you would want the lights to be on all of the time.
Lights are normally turned on by the key being turned on or by a separate light switch, as shown in the diagram.
boscoe99
Blue direct to yellow if no switch or blue to yellow through an on/off switch.
99yam40
there is a place that you send the gauges to to have then renewed,
But I cannot think of the name right off
