tg3690
- Joined
- May 7, 2019
- 1,116
That idle screw looks kinda worn, don't think that would keep it from starting. Yes, the timing could be off if the PO was jacking with it.....could also be a sheared flywheel key. The only way to know is to check it and see. Take a look at that thread I mentioned about the lync n sync.....it explains how to set up the carbs and timing....might make more sense then....
