Turn the boat, kill the engine.
airshot
Think you found your issue...next question...how did the water get in there and how will you stop/ fix it ??
fritzL
Thank you
I will drain and dispose of the petrol. How is the tank to be vented? I think I have a vent going through the hull, but do not see a loop in this line. I replaced the entire fuel line run from tank to the water/petrol separator last year with new 3/8 line.
fritzL
Next plan is to get a temporary fuel tank, about 5 gallons and go for a ride using that as the source for the fuel.
Please see below about your question... I am not sure how this water got in there..
I looked at the vent that exists, and did not see a source for the leak. Neither did I see a loop in the vent like I read somewhere it should have.
perhaps remove that and run a vented fuel cap?
The vent fitting near your fill port on the hull is 5/8". The line should have an immediate loop after the vent to prevent water
Google USCG cfr fuel system requirements
fritzL
Thank you for the reply. I will google and learn.
airshot
Also ...where are you getting your fuel ?? There are certain places where I won't buy gas due to there poor maintenence on there equipment which increases the chance of water in the fuel. Never buy fuel when the underground tank is being filled by the truck !! Never buy from stations that don't sell much fuel, busy stations will have fresh fuel more often. Without that loop in the vent line, any water at all gets funneled into your tank especially from spray hitting that vent. I have had that issue in years past...
fritzL
I have used the 30 gallon Craftsman drum shop wt dry vac on the tank. Then i duct taped a section of 5/8" vent hose to the vacuum line..
That got into the corners of this tank.
My petrol supply is rotated regularly. Its a shell station on a state highway. Which on tuesdays has 10cent per gallon price cut.
I just put in 5 gallons. Reset all electrical connections and taped any moving cables..
The vent hose was not looped for the "P" trap effect.
I bought new hose. Then Installed the new vent cap and this fancy anti slosh wizbanger.
I will try to take it out Thorsday ...
Thanks for reading
F
Not sure I would use a shop vac with arcing brushes and open framed motor for emptying a fuel tank. The fuel vapors go thru the motor.
It's a miracle you didn't blow up
fritzL
The tank gas been try and in the heat for several days...but yes, it coukd have been an insurance. Never mind
fritzL
Thanks for reading
F
Ayuh,..... With that coiled up hose, the vent, Ain't gonna vent, because of the trapped liquid,....
It should be like AD's image,....
fritzL
Thanks for teaching me. I will uncoil the hose. s the vent with built in "P" trap and the anti slosh tube sufficient?
F
