Yamaha Command Link Square Speed Gauge Not Registering Fuel
LIPowersports
Yamaha Command Link Square Speed Gauge won’t register how many bars of fuel in tank. The boat has two seperate tanks with new mechanical/magnetic senders (click the link)
For each sender/tank theres two wires; One tank has pink and black and the other tank has pink/black and black. I removed the senders and ohms tested, checked the sender grounds which connect to the tank, grounds behind helm, resistance tested the pink wires and saw no corrosion. Seems everything is connected correctly. Could the gauge be bad? Are the pink wires supposed to provide any power or these senders work primarily on ground?
dingbat
You posted a mechanical only sender
I've seen senders go both ways.
How does the wiring diagram tell you to hook them up?
