OptsyEagle
- Joined
- Sep 13, 2006
- 1,365
you mentioned that the plugs must be firing at bottom dead center?? How is that possible the motor can’t be 180 out, unless the keyway is sheered. But when I put the new keyway in it only whent in one way and corrected the 180 out… please correct me if I’m wrong I’m just confused as to what is going on with this motor at this point.
If the wires from the flywheel to the coils are switched, where coil for cylinder #1 is actually going to cylinder #2 and vise-versa, your spark would be firing at precisely the wrong time, at bottom dead center on both cylinders. You would get almost nothing from the engine in that condition. The fact that you said the engine popped a couple of times makes me wonder if this may be 1 of a couple of problems you might have. Especially if it did not pop with the spark plug wires the other way.
