1989 Evinrude 88SPL (E88MSLCER) Cooling
drobertsobx
OK, I have to admit I am stupefied... When I took the water jacket covers off they were caked with salt lime calcium whatever... I've spent the last couple days descaling everything and inspecting for damage (1 jacket cover was beyond repair)...
I just was dry fitting the gaskets to be sure they were correct, and it occurred to me:
There are no holes for water to enter into this jacket.
It is literally a flat gasket with just holes for the screws.
How is this designed to work?
Does water flow through this?
I triple checked the gasket it is the correct one.
Did all that crap get in there because the gasket failed?
I'm all confusion o_O
Take a really good look at the cylinder head / head gasket and see how water flows.-----Hint----The water flows towards the hose outlet and then to the thermostat.
drobertsobx
No I know that, water flow through the head didn't confuse me... I'm talking about the water jacket cover, It was totally caked with crud in the channels, like 80%, I assumed it was from water flow and little clearance between the gasket and the cover, there wasn't enough gasket material left to see what was going on...
I see no way for the water to get into the cover unless the gasket fails. That's why the channels in the cover are confusing me.
Is there a channel / port in the bottom and top of the head??-------And remember they made this cylinder head from about 1973 to 1998.----I think these folks knew how to build elegantly simple motors !!
drobertsobx
Here's a pic of the top of the head with the gasket in place, with the cover inverted to show the channels that are against the gasket, they look designed to carry water to me, but no idea.
Second pic is one of the covers packed with crud.
Yes they carry water !!-----It should be easy to see how the water gets in there !!----Water does not go through that cover gasket !
drobertsobx
I guess if you say so, I still don't see how any water could get to those channels.
The only holes are the bolt holes and the holes for the spark plugs.
That means once it is bolted down those channels are on solid gasket between the 2 sets of three bolts.
Pic of the head with gasket now on the cover as it would be bolted down, the only hole being that for the temp sensor.
Like I said stupefied LOL
At the top of the cylinder head in your picture are there not 2 ports that go to the water jacket ?-----There are on a cylinder head off a 78 model that I just looked at !
drobertsobx
No
That's the head in the picture(block side down), the water is isolated to the channels around the cylinders by the gasket.
Every hole in that gasket is for a bolt or the overheat sensor.
In my mind if they wanted water in there the gasket would be something like this...
Look carefully at this set up.----Look for the 2 passageways as they are visible in your picture !
drobertsobx
Cover with bolts in place, book shows all bolts as seen...
???-----Just look at the cylinder head !!----I see the ports that allow water in that space.
drobertsobx
I am looking at the head, I see no way for water to get into the cover. Head with gasket and bolts cover not on top of it... That cover is isolated from the water that comes from the top flows around the cylinders and exits to the thermostats in the head. Again talking cover not head.
tphoyt
I’m just as curious Racer.
Should there not be a cutout in the top and bottom of that gasket? I see the ports in the head but no way for water to pass.
drobertsobx
Are you referring to the 2 short channels?
Sorry----I cannot offer any more help on this.-----You need to take a long look at this !!
drobertsobx
Thank you, so it's not just me. There is no way for that cover to get water.
tphoyt
I wish I had an answer for you.
Just looked at the gasket on line as you I’m sure you have found they all look like your.
Please let us know when you get it figured out.
All the Beat
