jitterbug127
- Joined
- Feb 6, 2023
- 658
Not at all! Looks good!I mean where the flywheel meets the woodruff key is that worn
Can u show a picture of the choke on this engineNot at all! Looks good!
I can do that!Can u show a picture of the choke on this engine
I rebuilt carb 2 month ago. It has been used 3-4 times per week since. I’ve probably got 50+ hours on motor since carb was built. Fuel is less than month old, mixed properly, used the same tank and bulb I always do. No air leaks to note.So as far as we know good compression good spark, carb all clean and all jets cleaned and no air leaks ? Is fuel new and right mix ?
I think it should be fine. I have used motors numerous times without fault since it’s been rebuilt. I could blow air in carb when it was right side up and the carb wouldn’t let me blow air in when it was upside down.Also a thought you said the carb was rebuilt was the float switch set correctly so only fuel enters the carb before the float pin engages I have known Air to enter with incorrectly levelling to floats in carbs
Ok so im wondering whether the choke solenoid is stuck and letting in excess air without letting in fuel is yours a manual or an electric choke/primer valveI think it should be fine. I have used motors numerous times without fault since it’s been rebuilt. I could blow air in carb when it was right side up and the carb wouldn’t let me blow air in when it was upside down.
Manual choke, rope startOk so im wondering whether the choke solenoid is stuck and letting in excess air without letting in fuel is yours a manual or an electric choke/primer valve
Ok have you tried the engine on choke onlyManual choke, rope start
Oh yeah. I get nothing. I even put it in drive/wot and cranked it with a drill. Nothing. I even sprayed carb cleaner in the carb to start, NadaOk have you tried the engine on choke only
Will try this eveningOk have you turned the idle screw to full lean and primed on choke only worth a shot just to try, if it starts it will use up fuel from choke and die out after 10 to 20 seconds
Let me know how it goes have a few more ideas to try and helpWill try this evening
It certainly is and im just trying to help maybe what I'm saying will not help but just trying to help out a guy with his issuesLearning how to start a motor.----learning how to diagnose a " no start " condition is a lost art.
Very true! That’s my goal with this experience to learn how to diagnose it. I’ve been through all the steps I know…Learning how to start a motor.----learning how to diagnose a " no start " condition is a lost art.
