jitterbug127
- Joined
- Feb 6, 2023
- 666
You guys are all great!!!
100% the key now I've seen this your flywheel isn't engaged with the key at the top of the crank
So you think I replace woodruff key and motor will start?100% the key now I've seen this your flywheel isn't engaged with the key at the top of the crank
Racer what troubleshooting would you do?The key looks fine to me.-----More trouble shooting needs to be done on this motor!!
To me I cannot see the key engaging with the flywheel with the pictures shown so yes I would change that first offSo you think I replace woodruff key and motor will start?
He said it was running fine and hasn't changed wiring as far as we know so would that be an issue ?Fact are needed and heeded to.----You fuel put directly into the cylinder.----The motor did not fire up and bark at you.-----That means it is NOT a fuel issue.---So why would you spend an effort and put another carburetor on it ?----It is a spark / timing issue.----The wire from powerpack to top coil is orange with a blue stripe ??
