silver_power
Thread starter- Joined
- Jul 8, 2009
- 334
Hello.
I have a dual engine boat with twin 377Mags MPI DTS Axius, serial 1Α605669 & 1Α605670.
The boat now has Vesselview, and analog gauges for the two engines, connected with Analog Gauge Interface, one for each engine.
I want to keep the Vesselview and change the rest of gauges with Smartcraft SC1000 Speedo-Tacho and SC100 multigauges, trim gauges etc
The boat now has the smart junction box which is merged with the two CCM's under the helm and a 6-way junction box which connects the Axius components (Compass with Gyroscope, steering actuator DTS throttle control and the Smartcraft display multi-ignition 5A.) The 6-way junction box has 2 empty plugs.
The Smart Junction box has 2 plugs for Port Smartcraft display and 2 plugs for Starboard Smartcraft display. Now, the Port Smartcraft display has 1 available plug as the other is connected to the port additional relay kit and the Starboard Smartcraft display has none, as the one plug is connected with the Starboard engine's additional relay kit and the other plug is connected to Vesselview
When i will install the smartcraft gauges (SC1000), i suppose that the Speedo can be connected to the one of two available plugs at the 6-way junction box, the sc100 gauges for each engine will be connected at vesselview's link connectors, the Port Tacho will be connected to the available plug at Port Smartcraft display (at smart junction box), but i have no available plug for the Starboard Tacho.....where shall i connect it??
Thank you very much.
