Do you have the harness out of the donor boat? you could cut the connector off and splice onto your existing boat harness. Or get a used boat harness for the plug. I think this 3 ft harnes could be spliced in to boat harness as I believe the engine has female pinsHi all need some help. Swapping from OMC 305 to 350 Merc. Engine, inner and outer and outdrive. Boat has a 8 pin harness and 350 Merc has a 9 pin. Do I need to change boat harness or engine harness? Or is there something else I need to do?
www.michiganmotorz.com
Yes correct the one pin is unused. I believe they should work. You are smart to get a complete drop in vs piecing it togetherBought the boat with no engine, drive or inner/outer gimbal. Bought the engine as a drop in so no donor boat . I realized today upon closer look that the one pin on the 9 pin is empty. So I may be fine. Thanks for all the help. Im gonna need it with this project.
Would agree strange someone janked the entire drivetrain out of it given the condition?Boat is clean for age
Outdrives are common to get stolen and the insurance is normally on the boat owner not storage location.... People should just keep their effing hands off what is not theirs...The story I was told was someone stole the outdrive, intake man. and carb, exhaust mans and heads off the engine during winter storage. He sold block and inner and outer to a guy. I dont know if true or not. I got the boat and trailer for $800 he wanted $1200
I agree. I park my boat where I park my tractor trailers. We have trucks in and out all hrs. Locked gate a security cameras everywhereOutdrives are common to get stolen and the insurance is normally on the boat owner not storage location.... People should just keep their effing hands off what is not theirs...
Hammer test is lousy. Drilling some holes in tension and stringer imo it's the only fool proof way to test condition. Everything is accessible with the engine out, and definitely worth doing to make certain you're not putting lipstick on a pigChecked the transom and stingers with a hammer all are solid. Can see the transom wood through the keyhole. No delamination.
