dannyfranco
Thread starter- Joined
- Sep 10, 2023
- 6
hi there ,does anyone know how to winterize a 145 a Volvo penta with a 280 outdrive
Thank you for the reply Scottread the factory service manual.
change engine oil
remove all the drain plugs exhaust manifold, engine block
remove the lower j-hose and drain
remove the raw water pump cover and pull the impeller for the winter
pull the drive, inspect the u-joints and bellows
change the drive fluid
Got it, thanks so much.So winterizing in a FWC engine is different than a RWC. Since you mention antifreeze I assume it's a FWC engine. Test the antifreeze or extract a little and put in a Dixie cup in your freezer overnight.
I would suggest you review the owners manual for winterizing instructions. Most are online on the VP website. On my 2012 V8 engine I remove a blue plastic drain plugs from each risers, pull the hoses from the raw water pump and disconnect and drain a small hose that I believe goes to the fuel cooler. That's the engine.
Typically people change the engine oil, outdrive gear oil, maybe pull the outdrive and grease the U-joints.
Don't drain the block if you're closed cooled. Post 2 was meant for raw water systems..Check the antifreeze with a coolant hydrometer which is available at most auto stores, that will tell you the amount of freeze protection.
So yes leave the antifreeze in the engine.
