yorkington
Thread starter- Joined
- Sep 4, 2023
- 13
I bought my first boat knowing it wasn't running, and it has the 1988 Mercury 60hp. I'm an automotive mechanic by trade so I thought I'd have no issue with this outboard, but I'm very perplexed.
Here's where I'm at and what I've tried:
All cylinders have similar compression numbers, just above 120, with a deviation of 4psi between the highest and lowest.
Spark plugs are new, new stator, and spark is good jumping at 7/16".
Have cleaned carbs and have followed the factory manual. Floats are set at level specified in manual.
Flywheel key is good and isn't moving or damaged or anything.
Can't get it to run with starting fluid, might fire once or twice, but definitely no more than that.
Using new fuel and 2 stroke oil.
I'm not sure what I'm missing here. Let me know your thoughts.
