Transom Repair, Caribbean Jaguar.
Wildey81
Hi All,
Merry Christmas!!!
I’m hoping to get some advice, tips or tricks regarding transom replacement.
I recently purchased a 1978 Caribbean Jaguar which requires a transom repair, I’ve done some research and confident it’s something I can tackle at home though I’m hoping for some tips and tricks from those with first hand experience.
I’m new to the boating scene so anything would be of valve.
Cheers
airshot
If the transom is bad, the stringers will be worse ! Gonna need to remove floor and get down into the skeleton of the structure. You have your work cutout, time, work and money, it will take a lot of each !! Be sure you have good safety gear, breathing fiberglass dust and fumes can be deadly..
Welcome aboard
All the information and guidance you will need is in the stickies at the top of the forum
4th sticky down has all the DIY links. Read thru links 14, 15, 18, 2, 3, 4a, and 4b in their entirety. Watch every video, look at every picture. It will guide you thru the restoration
Step 1 on your boat was to remove the motor
Step 2 is to derig the boat
88 Capri (2022 SOTY)
Throughout an endeavor such as this take your time and take lots of pictures and measurements, things can shift during the demolition process.
It just makes things alot easier when putting her back together.
stresspoint
have you got the screen ? very hard part to come by if its not there as Carrebean boats no longer exist , not sure why as the built a damn good boat for a mass production hull ..
the jaguar was a good boat and was a solid ski boat , not many left on the water these days (guessing you may be in Australia ?).
:) build that transom for a 250 4 stroke and that boat will be as good " if not better " than any modern boat in its class .
Wildey81
Welcome aboard
Hey Scott, not sure what you mean by stickies?
I’m new to the forum and currently using on the phone.
Will that make a difference?
In the restoration forum at the top where it says "How tos...."
Put your phone on desktop mode.
Every forum has threads stuck at the top like post-it notes. Hence the term "sticky"
Wildey81
Thanks All, I figured that one out.
Next question, my bevel line sits between the 2 bung holes in the rear with a small space in between.
Should I cut and bevel between the 2 bung holes or above both?
I would pull the rub rail and pull the cap. Minimizing the cutting
Wildey81
Well, I bit the bullet and went for the external method.
Thank you all for the advise, it certainly made it a little less scary.
just the external patching and flow coat to go, oh and assembly.IMG_3676.jpeg
jbcurt00
Was the transom you took out 3pcs?
Multiple piece transoms, esp for OBs, is typically less then ideal.
Plywood looks untreated/sealed?
Was transom ply bedded into inner fiberglass transom skin before installation?
Drivewayboater2
Wow you took the plunge.
I’m with jbcurt….. hope you sealed the wood before installing.
Is the transom flat? Picture with the 2x4’s looks like they are bowed in the center. You might have trouble mounting your engine if it’s not flat.
If the transom is rotten, most likely the stringers are also rotten
Did you drill test them?
Wildey81
The transom I took out was one piece.
The new transom support is in 6 pieces, 3 inner and 3 outer with offset joints.
The new inner core consists of:
•2 layers of fiberglass matting and resin.
•15mm treated marine ply(sealed ends) in 3 pieces.
•wood laminating glue.
•15mm treated marine ply(sealed ends) in 3 pieces with offset joints to lower board, laminated to inner layer.
•2 layers of fibreglass Mat and resin with the original outer skin laminate on.
All bolt, bung and drain holes resined after cuting to seal.
Yes the end of the stringer was soft. 1-2inch back in. (I assume this is due the upper tub drain being the source of the leak) I managed to dig out the soft bits and resin the tips with the first coat, not ideal. But it’s summer here and I’m keen to put her in the water.
