- Joined
- Mar 8, 2009
- 44,268
Foam doesn't provide increase in buoyancy, the size of the hull does. The foam is used to stiffen the structure and can keep the boat from sinking to the bottom if swamped, but this depends on hull design and amount of foam.
The boats weight limit is there for safety. A overloaded boat can become unstable and be swamped easier. So if you and 2 others will exceed the weight limit, then maybe not a good idea
Asking questions will give you good answers "IF" the owner is honest and does know what they are talking about. You need to know what to look for and how to test to verify, or bring someone with that does know
Many have exceeded the HP limit, but do check with your insurance company before doing. A 85 HP 2-stroke motor will weight less then a 85 HP 4-stroke. In most cases a higher HP 2-stroke will also weight more, so keep this in mind when proceeding with max weight limit
