Chuck4741444
Thread starter- Joined
- Jun 6, 2020
- 146
Problems,
I ran motor on muffs at high rpm. Impeler melted.
Replaced inpeller, no water.
Remover LU again. Impeller was turned backwards is my guess, it shered the white shim.
Installed the impeller the right way. Still no water..
From what information i get online or from manual doesn't help. Is this water pump set up correct? or should the garment on top be installed inside the midsection?
There is no blockage from the pump through the tub.
How can i check for blockage in the midsection? The motor was just removed and rebuilt.
The old impeller melted, it didnt come apart.
