1975 oday 22
flashback
I suspect it would, I used a plastic cutting board to make pads for my cam cleats on the primary winchs.
1975oday22
on my motor mount wedge and motor mount. looks like someone used just silicone. there is no rot . should i take this all off and seal with 3m 5200?
1975oday22
well got the head installed , just need to get the vent hose , removal hose and a fitting to attach to the deck pump out
might have to cut the toilet sole and make a floor below it so i can extend my vberth
flashback
So, the porta potty gets pumped out. That is gonna be an expensive situation. Most marinas I know charge by the operation not by the gallon.
1975oday22
or i can take it out and dump it . its either or...
1975oday22
well, i just went and picked up my tender. seeing as i have to anchor out i figured i would have to get one anyways. so the reason behind me having to anchor out is that noone will come this far to do a survey so i can get insurance. noone is going to give me insurance. and seeing as insurance is not mandatory here in canada. i will not be getting it. so the boat slips where i am want insurance. its less than 35000 people. and 18 slips. on a small lake. (look up elliot lake in elliot lake) . anyways here is my tender for getting back and forth. aquarius 860 ordered my ladder today will be here on sunday.
aspeck
Put a 90hp outboard on her and you are good to go! :p Yes, I am JOKING! ... legal disclaimer - DO NOT DO THAT!😂🤣:eek:
1975oday22
lol, although it would be fun, even i aint that brave. ... i will be putting on the max is 30lbs thrust.
1975oday22
well I got my ladder today. i thought it woulda been wider. its pretty narrow. but it will do the job. havent done anything with it yet. should i bolt it through transom or use the supplied screws?
flashback
Looks like you have some extra screws to hang a picture or clock.
By all means, bolt that sucker on and back it at least with fender washers.
1975oday22
wich height should i be putting this at. picture 1,2,3 ?
flashback
Does your boat have a pulpit,? You want it high enough to get over, but low enough to climb up.
1975oday22
well im still not mounted. been procrastinating. i wont be using washers. but my backing plates are made of delrin. i will be shaping them before installation continues. i had to drill the mounts a bit bigger to accommodate the bolts.
1975oday22
well it is now installed. delrin as backer plate. will be adding fender washers as well
