GSX455
Thread starter- Joined
- Aug 21, 2016
- 165
I recently rebuilt carbs and replaced the water pump impeller. Model J90TSLECM
When I did the linkage after dropping the lower unit, I’m pretty sure I left it in neutral. Does the red circle looks about where it should be? I tweaked the upper thumbscrew, but afterwards remembered you probably shouldn’t adjust that?
Is there a guide on the forums for adjusting the carbs linkages?
Thanks
Thanks
