I'll try that, if I can't find the part!i have used car door edge trim...come in diff.sizes on Amazon
some use fuel line sliced down the middle and glue on. "Goop" works pretty good
I will.Have a look at AOMCI classified
Thanks!
black | 25-30-35hp (RD) | 1955-58 | 5ft | $69.00 | 304018 | | 304018 |
BTDT.some use fuel line sliced down the middle and glue on.
I just checked out his website. Those are some cool restorations he did.The list of cowling seals is from------nymarine----A good guy in Ontario , Canada
see also ..
black 25-30-35hp (RD) 1955-58 5ft $69.00 304018 304018
Oh! THAT makes sense. I should have thought of that, lol. That's not too bad.That would be $69.00 in Canadian funds.----A good deal if you ask me.
I don't have the pump for the oil, so maybe I need to get one.If you have the pump for the oil you could adapt that to work with a bike pump. If you don’t have a way to hook up a gauge drop it in water and look for bubbles. It only needs like 10 psi so don’t over do it with a compressor.
Yeah, I just looked and I need to get one. I never knew you were supposed to fill up the gearcase from the bottom!I don't have the pump for the oil, so maybe I need to get one.
I will do that in future. Thanks!You always fill from bottom till it comes out the top.----On more than one occasion folks came to the shop with burnt gears / bearings.-----They made the mistake on a simple job.
