charliedaubitz1
Thread starter- Joined
- Jul 29, 2024
- 83
The drain line on my exhaust is plugged. I removed the manifold and have ordered a new one. The line I think is a bypass line that runs from the coldwater supply line coming through the transom from the impeller to the t is where the manifold drain is looks like it pumps cold water into the manifold jacket, Is that line to help keep the riser cool till the block fills and starts circulation. I'm replacing both the riser and the manifold. The riser was cracked on the outside and staining the manifold, no leaks inside. I have overheating even when the stat is out, new impeller and lots of water pressure from the impeller. does the circulation pump ever go out without making bearing noise, turns fine. I'm changing the manifold and riser because I think it's restricting the water flow, I'll soon see, parts will be here Monday or so.
My new manifold just came in. the exhaust port is large and rectangle, the merc cruiser gasket that came with it isn't the same size and has a vertical gasket in the middle of the port with no surface for it to mate against it, do I trim the gasket to match the port?
