Scott06
- Joined
- Apr 20, 2014
- 7,685
What you have just makes no since as to why it's happening. If it was the manifold then why doesn't number 6 have same issue. The hoses are routed the same for both manifolds and in most all cases the port side does get a tad bit hotter the the starboard bank.
Scott's idea may provide some insight into the problem.
Take a short piece of clear hose and place in between the manifold connection and hose, and another piece between elbow and hose. Want to see if there are any bubbles in either hose
Yeah was thinking if there is air being sucked in either on inlet side of water pump (supply to engine) or if say a head gasket is putting combustion gasses into the cooling and it is allowing that manifold to get hot
