Lou C
- Joined
- Nov 10, 2002
- 14,508
Most mechanics I know around here like BARR if you aren't using OEM.
I have to say this is one of the most mysterious engine problems I have come across.
While some might argue, I think BARR is very close to OEM quality. Other than the cyl head on that side being out of level as far as the exhaust ports, or a clogged water passage that puts much more heat in one spot, it is very hard to imagine what's causing this.
When I had my bad overheat (raw water hose from transom popped off P/S cooler on back of the engine) the manifolds got to 375*F (temp spiked but bilge was very quickly filling with water....I was trying to beach the boat, didn't know why at that point water was filling the bilge, lol), and they were the infamous batwings and THEY didn't crack! Used them 3 more seasons! Waiting for the tow in, I took out my IR temp gun and measured them for a good laugh on a bad day.
However I found out a few years later, the cyl heads did crack, yet, till the HGs started leaking, it ran the same as always.
