Chuck4741444
- Joined
- Jun 6, 2020
- 109
problem: rough idle \ runner good at wot 21 ft. CC running 32 mph that's what it was before rebuild
Things I've done.
1. tested the coils
2. test resistance on plug wires
3. tested resistance on plugs
4. tested plugs for blue spark.
5. set the timing @ 6 btc per manual.
6. removed 6 carbs and throttle.7. cleaned and wired every hole. (Twice)
check reeds buy looking for light shining through them ( replace 2 that were not closing tight)
7. set mixture screws at 5 turns per manual. turning in only effect 2 carbs.
8. reinstalled them.
9. Motor fires right up when its warm.
10. I have pulled the plug wires one at a time. 3 of them does not change the performance,
11. I can cover and flood that card and nothing changes. full pours out when I remove my hand.
12. sprayed carb and chock cleaner around throttle plate, carbs nothing changes.
Is it possible that I have 3 bad plugs? their fairly new.
or could it be reeds" I don't have fuel spraying form the carb, as before.
is there any way to check the reeds without removing the again?
thanks for any help.
Things I've done.
1. tested the coils
