Mercury thunderbolt 500
Dionw
The Key that connects the Impeller
I can't find the woodruff key hole for the key, there's a slot for a wrench but no slot. I'm going to try and put back together and check all the vitals, spark, compression, fuel... is this the fuel pump in the photo?
jimmbo
There is no hole. The Key in this case, fills the Void in the Driveshaft
Remove the 2 narrow covers above the fuel pump in the picture.----Allows you to look at pistons / rings.
Dionw
Will do thank you, will put up dates, in the mean time I'm still looking for a manual in nz
