How long is the skeg on a mariner 30/40
chrisgt
I have bought a boat with a 1996 mariner 30 that has a damaged skeg. I straightened it out and plan to weld on a replacement cast aluminum skeg with 5356 but I have one problem...
How long is this supposed to be? I'm assuming maybe 1/2" or so below the prop? Any help would be great, thanks!
boscoe99
Is that a Mercury Mariner or a Yamaha Mariner?
I don't think the length of the skeg is critical however.
Should be a tad longer than the prop
You could put 2 straight edges on the undamaged parts of the skeg, and see for yourself the length and shape.
hope you at least pulled the vent plug to relieve pressure from the heat when welding
dingbat
Aluminum dissipates heat very efficiently. Not enough heat to do any damage.
Would be more concerned about damage to the electrical systems if the battery wasn’t disconnected
chrisgt
I didn't pull any gear case vents; I put a wet rag over the gear case and welded an inch, then let it cool for 10 minutes, and welded another inch. In between these passes the rag didn't even start steaming, stayed cool as a cucumber. I'm sure it gets hotter sitting outside in the summer.
Aluminum does dissipate heat well but you also have to be careful with it, it's easy to get a runaway heat soak condition where the whole part goes from being cool to thermonuclear in what seems like a split second.
I clamped my ground right to the skeg, so no current to flow through any part of the electrical system. The electrical system on this thing is basic and all the ignition stuff is isolated from the battery anyway; it's all run off the stator to the ignition components. I have never had an issue with electrical systems and welding cars, as far as i'm concerned disconnecting a battery does nothing; if you're gonna fry a computer with high frequency start or magnetic fields, you'll do it with or without the battery.
I'm an electrical/embedded engineer so I have some vague sort of inkling of how electrical systems work...
the heat causes pressure, pulling the vent makes sure you dont pop a seal
chrisgt
I put less heat into the gear case than sitting outside on a hot day. With a thermal gun I measured 90F at the gear case.
you should be good. pressure test to make sure.
Fun Times
So just to help clarify the main topic title question, was sort of wondering how many inches did it turn out to be say compared to the chart of that website as reference?
PS: nice job 👍.
