redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,456
so... it will begin this spring would like to be back on the water in a few weeks. I can take the time off but want to have most of the research, supplies and such in place to complete quickly once it becomes my full time job to complete.
Have a leak i cannot identify from the outside and it is getting worse - https://forums.iboats.com/threads/leaking-riveted-starcraft-82-mr180.771335/
Small soft spot in the floor getting worse because i have a leak. Endless loop.
I will be doing a floor replace and of course a leak fix once identified. added flotation, adding fuel tank, moving battery forward and, a few other things.
So to get the ball rolling I would appreciate some input:
Pour foam or pink board
If pour foam, epoxy wood or thin aluminum
Either floor choice, cover with nautelex or some sort of rubberized/sanded coating
Any thoughts on what you would/wish you would have done with the floor out
This will be my last boat unless i win the lottery and this will be the last time i go all in on this kind of work so it needs to last about 20 years until i die.
