Mercruiser. Reusing new transom seal?
jonny rotten
New seal. I cranked down down the transom assembly then took it off 5 minutes later. I know you don't reuse old seals. If there something about the seal that makes it a one time (5 minute) use on a new seal. It bounced back but maybe not quite all the way round
Fun Times
From your description 'you seem good to reuse the new seal again as they are for the most part reusable if not damaged, etc..
bajaman123
As you note...it is a very important part...and some would say, why take a chance? My thought would be it never had a chance to "take a set" so you should be fine.
