Freeman1982
- Joined
- Aug 19, 2020
- 77
Hello guys I back again for the same problem, my regal 2100 take long time to get on plane some time I ask passengers to move to front seat which that will help.
I changed fuel injectors and spark plugs with wires, and replaced the zip cap distributer cap, replaced the fuel pump, I did compression test they between 120 to 150 while engine cold, checked the lower unit oil is good, checked the lower unit screw if have a metal debris it was clear. Also I put new propeller , I just need to put new engine lol.
This usually happened after spending 40 minutes at the lake when engine is still cold boat get on plane with no problem , but after 40 minutes this issue will start .
Please LMK what could be the problem ???
Engine info below
50gxic 270 /
A196003 /
40869324/
Engine info below
50gxic 270 /
A196003 /
40869324/
