New block everything was fine first hour. After, some noise from camshaft. Sounds like bearing ticking. No noise from intake. When cold no noise. Was thinking valve lifters or valve adjustment. Did the valves again. The same noise. Could it be lifters? They look fine. However one has slight scratche on the bearing of the lifter. Compression is good all cylinders, runs good, timing good, all torque to the specs. Also thinking noise is due to conventional oil with zddp adding. Too early to try synthetic. Not a pulley or belts nor pump, tryied with out the same noise. Plz help. Running out of ideas.
