power trim removal of center cylinder
acadian2022
good day all. could someone explain how to remove single center cylinder for a replacement see pictures. I see the top part will be a pin to knock out its the bottom one not sure how to go about it. thank you all
acadian2022
hi all. I assume I need a puller of sort my concern this is was used as a salt water engine and when I removed those covers to expose the center pin with center threaded hole I'm assuming it's going to seized had slat deposits inside of the cover. will spray penetrate WD-40. I have another post regarding this engine wanted to seperate the topic thank you once again for any help on this.
acadian2022
perhaps the center hole is a reverse tread bolt that is required?
acadian2022
I think you put a threaded rod in there.----And a slide hammer.----Perhaps your local friendly shop will pull it in minutes.
acadian2022
I was thinking about that... and have such a tool :) what the heck will give that a try thank you...
acadian2022
Yes North Coast New Brunswick
Quick update nothing Ive done worked. I was able to tap a new hole in the ram and got the power trim system to work for now this will do and get back to this another time thank you all for all the suggestions / help
