Capt dave 258
Thread starter- Joined
- Jul 14, 2021
- 102
I have a 1988, 125hp Force outboard. Don't know any history on it, other then it sat for years. Had no key for the ignition switch when I bought it and purchased a new ignition switch online. Had it fire up briefly before I installed the new igniton by jumping the solenoid. On a side note, the boat was junk, so I disconnected all of the wires at the dash and pulled them back to the motor and hooked up the new ignition switch. Never had spark again. Read over forums and saw that I should disconnect the white wire for the stop switch, where it mounts to the wiring block. Did so and the motor started. I had to touch that white wire to it's terminal to shut off the motor. The other end of that white wire goes directly to a terminal on the back of the ignition switch, there is no stop switch in-between. A wiring diagram from Master Tech, shows some sort of stop switch, but I don't believe I have one. Doesn't the ignition switch act as the stop switch? I also see that there are 4 different ignition switches listed for this motor. Perhaps I bought the wrong one or have it wired wrong? There is no kill switch near the shift control handle. Any thoughts or ideas are appreciated.
