1988 125 hp Force rebuild
Sandy-man
I was with this group back in 2019 shortly after my Force motor overheated and shut down in the middle of Lake Erie. I posted pics of the number 3 cylinder walls being heavily scored and was told I needed to have the cylinders bored out to the next size, etc. After taking it all apart and having the cylinder block inspected at my local machine shop I found that the previous owner had already done this once and the cylinders were at max oversize, so the cylinder block was nothing more than a boat anchor. Took me quite some time to find a cylinder block in good shape and it turns out it is still OEM bore size and in perfect shape. I also bought all new Wiseco pistons and rings, OEM size. That all happened by Nov 2019. So, my torn down motor has been sitting for nearly 6 years while lift just kept getting in the way of me finishing this rebuild. I finally retired this past spring and find myself with lots of spare time on my hands. So, back to the motor I go.
I am currently waiting for a new labrynth seal as I found one to have a large piece broken out of it. Other than that I am pretty certain I will be on my way to finishing this rebuild once the seal arrives next week. In my conversations, back in 2019, with a few of the very mechanically inclined individuals in this forum somebody mentioned something about needing to apply some black silicone gasket material somewhere near the top of the motor, if I recall correctly, but I don't recall precisely where it will be needed. I would have all this info at my fingertips if I could have successfully signed in under my original membership account, but I was unable to do so.
I would also like to add that this is the very first outboard motor I've ever worked on other than simple fuel system cleaning. So any helpful tips from anybody would be very greatly appreciated. I would love nothing more than to get my Bayliner back on the water by next spring if at all possible.
Thanks for reading.
Nordin
The gasket for the exhaust tube F439736 is N/A and if it is bad you have to make one of your own.
If it is bad exhaust will leak and maybe it will come up under the hood and the engine will breath some exhaust instead of only fresh air.
The gasket exhaust lower 809825 is N/A and you have to make one of your own.
Maybe your 125Hp do not have this gasket as when I look at the parts diagram it is not there at the Force engines.
The earlier Chrysler 3 and 4 cylinders which are very similar to your engine has this lower gasket.
The gasket should be between the adapter plate and the motor leg.
Sandy-man
Thank you. I will look at that more closely than I have to see what it has and will also look at my complete motor gasket kit.
jerryjerry05
I do still have the old block, but the seals I had to order are the labrynth seals that are physically on the crank shaft between each of the lobes.
If you can get them off without breaking them?? use them.
Sandy-man
The replacement cylinder block did not come with the crank shaft, so I ordered a new one from Boats.net. JeryJerry, I do remember your name as being one of the long time members of this forum who provided me with valuable input for me when I first started this project back in 2019.
I would love to be able to recover the conversation I had with you all back then because there was some very valuable pointers by several different members, but when I tried to reset my password, an email was supposed to be sent to me for doing so but I never received one. I tried probably 4 or 5 times to no avail.
lgaytan
Good luck in your rebuild I've been in mine for almost two years now, I went the short way put everything together just by honing the cylinders and changing pistons and rings got 105-115 psi after that in all three cylinders so I think that was it, but when tried it in the lake I couldn't get power, the motor bugs down and then dies, idle and slow RPMs are no issues, then with help off Jerry as well it seems I have some sealing issues, fumes coming from the exhaust port and other things I haven't been able to fix in this years. Recommendation from my part take your time get service manuals, pay attention in all seals gaskets and silicone application, the service manual is very detailed in that.
Sandy-man
I finally got back to working on this rebuild after many life stressing events. I now have the motor all put back together except for the electrical hook ups, throttle linkage and flywheel. I broke a small piece off the flywheel when I was pulling it. Like the lame brain I can be sometimes, I first tried pulling it with my biggest 3 jaw puller, which caused the break. Then I got smart and made a puller like I should have to begin with and pulled it in the manner the service manual shows.
Anyway, a few days ago I went back to view all the pictures I took of the motor before I started the teardown and during the process. Much to my dismay I could only find several pics I took of the electrical wiring, and I seem to be missing some of them as well.
Now I'm hoping I can get a fellow forum member who may have a similar motor to take a few pictures from different angles of both left and right side of the motor, including throttle linkage and mechanisms. This would help me tremendously in the final chapter of this rebuild. I can almost feel me lowering the motor down onto the lower end and bolting it up.
Sandy-man
Sandy-man
Here's another stumbling block of mine. All of the wires except for one out of each of the two C-D units were never disconnected when I tore down the motor. The one wire I had to disconnect I cannot find where it goes. One unit the wire is black with a yellow stripe and the other unit the wire is white. Both of these wires are coming out of the same spot on each of the C-D units. The service manual says the white wire goes to the terminal block. Can I safely assume that the black with yellow stripe goes to the same spot on the terminal block? Please see pics I provided. Thank you.
lgaytan
I have a few pictures of mine a 1989 85hp, maybe they can help you.
Sandy-man
I thank you very kindly. These might help me some with the electrical hook ups. I really appreciate it. I have been surfing the web and looking at every picture I can find. A couple of which helped me with some of the linkage. I don't have too much more to go before I can finally get this beast off my work bench and lowered back down onto the lower end or motor leg, whatever it's called. This being the first outboard motor I've ever owned and worked on, I am very unfamiliar with the terminology.
Sandy-man
I am terribly sorry, I just read in another thread that once a thread gets to be 90 days old it is Forum policy to start a new thread. I started a new one last Thursday and will move all future replies/posts to that thread.
