Cabinet hanging question.
cyclops222
Some of us are spoiled by Building codes that specify 16 on centers for all walls and ceilings.
I helped a friend modify his trailer house. UNREAL the short cuts the factory used to build it cheaply.
redneck joe
I marked the studs on the floor, but I should have done that before I covered all the drywall screws. It would've been easier.
My place isn't built like that. It's a very old trailer home with 2x2 studs, a single stud header, and rafters sitting on top of the studs. It even still has the rafter for the original flat roof.
Those would go past the studs.
2in stud + 5/8in drywall + 1/2in cabinet panels = 3 1/8in total. I'm puttinf in as many screws as I can, and the 2 deeper ones are also getting a row going up into the rafter.
I should also mention, the neighbor has been helping me. We took a break for lunch before picking this one up yesterday, but he didn't come back. He's in his 80s and was splitting wood all morning before that, I'm not going to complain.
A magnet finds screws
tphoyt
I still used my grandfather’s magnetic stud finder
up until 6 months ago when someone walked off with it. 😡 it was very handy in old home with randomly placed framing. Such as my house which started life as a 600 sq foot chicken coupe in the 50’s I have added on over years and Im up to 1,400 sq now. But it was really handy for the old lath and plaster walls which I deal with on a regular basis in the buildings where I work. They were all built in the mid to late 1800’s. I guess I should look for another one some day and see if anyone still makes them. If any one knows let me know.
tphoyt
Just took a look on flea bay. No luck but it was very similar to this one only it was a red case and more rounded.
MikeSchinlaub
Anyone want to guess the mistake I made which made that one so hard to get in?
redneck joe
Got an online boat friend I've had for about 20 years that I unfortunately have not met yet in person but his place up in the Hamptons he took from a tool shed to his current house. He's an artist as is his wife. He did a yellow notepad for me
FLATHEAD
You’re in there out of square. Looks like you could shift it a bit to get it closer. You can make some adjustments with the hinges to line up the doors but you’re limited.
I’m looking at the framing around the exterior door. Seems the top plate is only about half the width of the studs. Not sure what the missing piece of 3/4 up there is all about. Those two cable protectors are overlapping each other, would be good to fix that before you put rock on that.
MikeSchinlaub
Are you talking about the pic in post 16? The cabinet was only resting on the stand in that one. I had to take the drywall and top door hinge out because I measured where it was going, but not the path it would take to get there. It was too wide, and even after taking the drywall down, I still got wedged on the nail plate and had to hammer it through.
FLATHEAD
Yes post 16. Didn’t realize you had yet to fasten it. I was referring to this area here.
Crazy framing right there. No sort of header as well. I see it’s an old mobile home, so that might have been standard back then.
MikeSchinlaub
There's a header. That is a pre hung door, which I framed with 2x4s. The header is 2x2, it's just barely visible in that pic, looks more like a shadow.
Ain't nothing standard about old mobile homes.
You have no idea. Half framed window, aluminum flashing over holes everywhere, speaker wire wired into an outlet and hanging cut under the house, metal boxed outlet under the house (presumably for heat tape for the water line), breaker box mounted to the 1/4 inch paneling...
MikeSchinlaub
Cabinets are all in now. I had to get some 4 inch structural screws because the tall one had a big gap at the back, and I used them in the tops of the deep cabinets above the washer and dryer too. Good thing, because I had actually missed the rafters with the 3 inch ones.
I also screwed the counter bases together, and the tall one into the adjavent cabinet to close the gaps.
