Johnson GT Ocean Pro
Mikko
I came across with this motor, decal saying J10GTRSSS, power 11.2 kW, which is 15 HP. Does anybody know whether this motor is 10 or 15 HP? There should be some reason for model number J10, if it actually is 15 HP.
J10 indicates Johnson 10HP. The rest of the letters give production run and year. The year is 2000, according to the crowleymarine site.
Mikko
Yes, but it also says power 11.2 kW? I have heard that this GT means that 10 is derated to 15 as kWs say.
A marketing thing.-----A 15 hp sold as a GT 10 or powerful 10 HP.----Some lakes are limited to 10 hp.-----And the factory decals say 10 HP.----Easy to me.
saltchuckmatt
You can't take a 10 and derate it to a 15....you can derate a 15 to a 10 though. Can a 10 be made into a 15? Yes, with different terminology.
As marked, your motor is a 10 unless it's been modified.
Why do you care? Just curious.
Mikko
Nobody really knows if this GT is 10 or 15 as the decal says 11.2 kW (15 HP) I think this model was not sold in US (export family) and this is why people are confused. I care since I am about buying one.
Test run it with a factory test prop.----That will stop the arguments.
saltchuckmatt
Well I should probably apologize then...never heard of a 11.2 kw cross-referencing a HP rating. And you are correct, reading the model number I would call that a 10 or actually a 9.9 because that was the "I don't have to register this boat" clause. So new one to me.
I have a GT 100....what's it's horsepower?
Race says to put a test prop on it... so I assume you will need a tach and a particular rpm for each range.
You certainly don't need to do it for me.
Cheers
Mikko
Not much difference with Evinrude 15. Boat 15.5 feet, 190 kg
  • 20251024_114824.mp4
  • 20251024_154636.mp4
The white motor is higher displacement compared to the blue motor.-----The ports are a totally different shape as well.
Mikko
Yes, Johnson is 2000 and Evinrude 1992, OMC went from 13.2 to 15.6 cu in 1993. Question concerns horse power which could be same 11.2 kW (15 hp) in both. I haven't compared the carburetors, if Johnson has a smaller throat carb (9.9 HP) or not. If it does, extra power comes from somewhere else (jets?) Speed was roughly same or both motors.
dingbat
HP= TxRPM/5250
Hard to believe a 20% increase in displacement didn’t result in an increase of torque as well.
WOT for both motors the same?
Bear in mind that rated and advertised HP can vary plus or minus 10% by law
The port shape and port timing are different on the 93 and newer blocks.----Soon I am going to install a newer block into a 92 and older version.----They run much nicer.
