Mercruiser 350 MAG MPI
AusFox
Gday to all the brains trusts here,
I have been assisting with a mates Mercury 350 MAG MPI that has had some running and hot starting issues.
The engine would run ok but after running for an hour or two if we shut it down to fish then tried to re start it 30 mins later the only way we could get it to start was to use the throttle and crank it for a bit. So we replaced all the spark plugs, set the timing correctly, changed the IAC, replaced the distributor cap and still had the same issues.
We then pulled down the GEN 3 Fuel cooler to look for the paint de laminating however that all looks fine. While we had it apart we changed the fuel filter and the screen and also sent the injectors off for testing and servicing. The injectors came back from a reputable Bosch agent fully serviced and told they couldn't fault them.
When we water tested it on the weekend after installing the injectors it started great but it was a bit slow to respond to throttle in the mid to top end so we slightly adjusted the timing and it ran better. However we noticed the fuel burn rate was allot higher than previous and we could smell fuel, knowing it was running rich we headed back to the ramp.
Once we returned to the ramp and shut it down it wouldn't re start no matter what we did so we took it back to the shed and tried again only to have it lock up! We then pulled the plugs out and it was obvious how rich it was running by the state of them and the port side plugs all wet so we turned the engine over and the rear port side cylinder threw out allot of fuel!!!
I am waiting on a fuel pressure gauge to be able to accurately check fuel pressure, but does anyone have any suggestion's or good diagnosing methods to help us out and find what the problem is? It seems the less restriction we have in the fuel system by changing filters the worse the problems are getting!
Fun Times
Hi, you'll definitely need to check your fuel pressure and it would be helpful to know your engine serai number so you (/we) can confirm your correct engine parts used/possibly needed on your end.
If it's running really rich then it could be other things too such as the fuel regulator is either bad internally or clogged underneath it/or the gen 3 top cover area under it too...You could try pulling off the vacuum line of the fuel regulator while engine running to see if it's flowing fuel out the regulator vent line and into the engine as it should not be doing so.
Other things could be bad to cause that much fuel in the cylinder may be a faulty MAP/T sensor, bad fuel damper up on the fuel rail, engine running way to cold, engine cylinder misfire conditions say bad cap and rotor, plug wire/s or boot ends, wrong spark plugs, internal valve issues, still misadjusted distributor system, crankshaft sensor or if installed on your engine model as you're right at/under the year of change would be the CAM shaft sensor if it's plugged into the back of the sensor sticking out of the HVS distributor assembly just to name few of many other possibilities still.
If the engine turns out to be hard starting when really hot (outside air too)
then sometimes you may experience a restricted water flow to the Gen 3 fuel cooler housing or inner water lines that flow through it all so bear that in mind as you go.
Sounds like you might not be in the USA? Might want to check your local ebay store to see if anyone may rent a Marine/Mercruiser scan tool or diacom setup to plug into a laptop computer system such as these two places that offer rental at $50.00 for 7 day, https://www.ebay.com/sch/i.html?_nk...2334524.m570.l1313&_odkw=rinda+tech&_osacat=0
That or buy the diacom system and start renting it out to get some $ back in your area and help your locals out too. :unsure:
The following is not your exact engine, ECM or fault code numbers as it mostly covers newer engine models but if desired on your end to study up a bit of different ways of thinking to help solve your issue, it might be worth checking it out.
Lpgc
I am no expert in these particular engines but I do know about fuel injection in general. Behind the scenes most fuel injection systems will give extra fuel for a cold start to give the same effect as pulling the choke on a carb engine. If you try to start a hot engine with that choke effect active the mixture can be too rich for it to start. Is there a temp sensor for the fuel injection ECU that could be faulty or disconnected?
AusFox
Thanks for your help so far! We are in Australia and don't have anyone we can hire a scan tool off that will work with Mercruiser!! I have 3 other high end scan tools such as G-Scan, Jaltest and Autel but none are able to work with this engine.
I hope to have the serial number later today but what I have also found out is that this engine was a "new" base engine 2 years ago after the original got drowned due to failed exhaust manifolds.
The previous owners purchased the brand new engine and intake manifold then had a marine dealership transfer all the electronics, fuel system and ignition system onto the new motor and installed it. For the first year all ran well and never missed a beat then the hard to start once warm begun and now since changing filters and inspecting the fuel cooler the over fueling issue has occurred.
Below is a picture of the ECM label
Lpgc
The lock up and rear port side cylinder pumping out a lot of fuel suggests hydraulic lock due to the injector on that cylinder being stuck open (or held open by constant power to the injector).
Injectors can get clogged / damaged if any debris gets into them through broken filters or if someone has the lines open and allows dirt to get in. I've known a few people do engine swaps but not plug the lines to prevent dirt getting in, replacement engine runs OK until dirt affects injectors.
Original problem was a hot start issue and now after injectors came back from testing the motor is flooding.
While the hot start issue may have been vapor lock, this issue is most likely the injectors
AusFox
Well my battle continues!!
After sending the injectors away for a test and service and telling them that if they have any doubts about them just replace them, I have found 1 of the injectors is stuck open, this has now been replaced. I have a full set on order just to be sure now!!
However, with the failed injector replaced I still have the issue of the engine running rich (black gas build up on the transom after water test), I get what seems some intermittent misfiring under load at times and the hot start issue is still present!
My fuel pressures all seem good and as follows:
Key on = gets up to 42 psi and settles on 34 and holds it
At idle = 36 psi
remove VAC line from reg = 43
When the new injectors arrive I will install them and see if that changes any performance however do you think I might have an ignition module problem? I have attached a photo of the module to get help to identify the system as this engine has had a new block and heads and I can't locate a serial number at all.
Should I just replace it? I see many aftermarket ones available are they worth a try as they are a lot cheaper than genuine.
Injectors tested and good
Later found 1 injector stuck open
Replaced that injector and still running rich
FT mentioned
I could just be a sensor telling the ECM it needs more fuel. As before you need a scanner to see what the sensors are telling the ECM.
Your fuel pressure looks good and don't see it being the module.
Have you checked the timing and replaced the distributor cap?
AusFox
I have replaced the cap and rotor, when cylinder 1 is at TDC the tang is on the number 8 on the dissy housing and I believe that is the proper location.
With a timing light on it at idle it shows the mark on the harmonic balancer to be firing around the indicator groove.
Spark Plugs have all been replaced and are NGK IRIDIUM TR55IX
This engine does have the cam sensor plugged in the back of the HVS Distributor, can this sensor be replaced or do you need to replace the whole assembly?
Crank sensor all looks ok but not tested.
I am trying to get a scan tool sent to me so we can see some data to try help a bit more.
Lpgc
I don't know much about this engine but agree with alldodge it could be a sensor / fuel trims.
Another thing is it's had a stuck open injector, one thing that can cause an injector to fail (stick open / closed / not flow fuel at the correct rate when open / bad spray pattern ./ etc) is dirt or contamination reaching injectors. I'd want to make sure fuel filters were in good condition and flush out the lines or fuel rail especially between the filter and injectors, then fit those new injectors... If you have one injetcor fail due to dirt / contamination you'll likely have more injectors fail for the same reason, while either the shop that checked the injectors didn't do a good job of it or you had an injector fail after the shop said they were OK. Maybe they were OK when the shop checked them, in which case dirt / contamination damaged one or more after you put them back in the engine, or if the shop didn't check them properly there could've been more than one at fault when you put them back in.
I once damaged a set of injectors on a Mercedes 63AMG engine by fitting a new flexible fuel line between firewall and fuel rail, I forgot to flush the new pipe through with petrol before fitting it. Before fitting new injectors I flushed the lines and rail by running the fuel pump with injectors not fitted so petrol came out of the 8 holes in the fuel rail, no problems after the flush and fitting new injectors.
What is the serial number?
The cam sensor can be replaced but right now I don't see it as causing excessive fuel. This that can cause excessive fuel are the MAP, Temp (MAP/T) sensor(s). TPS or a vacuum leak
You need a scanner, and while Dicom would be best the TechMate would help. Need to see what the readings are to see what the ECM is seeing. You just can't tell what is happening without the proper tools.
Your timing may still be off and the bulletin attached shows how to make a simple tool to verify accuracy (page 15)
  • Bul 2011 11R2 HVS clocking.pdf
JustJason
The appearance of an engine running rich can be caused by low engine compression. Before throwing money at this, check the compression.
AusFox
Hi guys,
I have not been able to locate a serial number yet as I the engine has previously had the block and head's replaced and all the electronics from the old engine got put onto the new engine.
All fuel filters have been replaced, lines all cleaned but will be doing that again when I install the new injectors.
I am may have found a Diacom I can hire, if I can get it what should I be looking for on it?
With it being a reman motor the serial number won't be there.
What year is the boat?
Jason does bring up a good point about checking compression.
Diacom will be able to read codes and that could be the issue. It also has a record feature, start recording from when motor is started until it's shut off. Can then export the file and post it hear. Can also take screen shots and post.
When motor starts running rich look at the MAP, TPS, Temp and timing
AusFox
Thanks alldoge,
The boat is an 80's caribbean and I understand the engine components to all be from around the 2008 time frame.
I will do the comps tonight and also look at the Diacom and report back what I see. On the hose it all sounds great and is smooth but when we water test we get the black exahust stain on the transom and a few small missfires/back fires when moving through the rev range. Then when we shut it off and try restart it wont start with out throttle.
I am sure its prob something simple and we have fixed many things on it so far but we must have a few more things to get right.
AusFox
What sprk plug's do you guys all reccomend for a 350 MAG Bravo 3? Currently running a NGK TR55IX (This is what was previously fitted). See attached the specs on this plug
Probably came with AC-932 but later Merc changed them to AC 41-993 and these are Iridium and gaped at 0.060
Finding the NGK TR55IX is used in the Ford F150 1997-2010, as well as older GM and a few LS1/LS6
Guess that said, the plug should work fine
AusFox
Thanks, I have found the crank position sensors brass threaded insert to be a bit loose so I have removed that and going to put some retaining compound on it so that I can eliminate the possibility the crank sensor is vibrating.
I am trying to find a new crank sensor here locally from a GM to also replace that while in this area!
AusFox
UPDATE
So I have now done everything I can think of without the use of the scan tool as I still can't get hold of one! I used my PICO Scope to monitor the crank and cam sensors, and they seem to be working correctly with each other.
Water test the boat and its running very well now with alot of repairs from dirty wiring, rectifying mounting threads for sensors and replacing all injectors.
How ever after sitting fishing for an hour the hot start issue remains! Running a temp gun over the engine I found the intake manifold was up around 140 degrees fahrenheit compared to 96 while running. Fuel pressure is still good and I tried to bleed it off to see if any signs of a vapor lock - all looks good but still would not start. I reluctantly sprayed some "aero start" for my own reference to see if it would try fire but it still would not try fire. HOWEVER I then removed the intake manifold sensor so that it would use ambient air and it fires straight away!
Would you suggest this indicated a MAP sensor fault once hot or something else?
Are the pics your manifold and Throttle body, with MAP circled?
