1995 Crownline 202BR Restore
beta
Tank is installed. I ended up having to breakout the sawzall to narrow the rear cleat next to the engine compartment. I had dry fitted it but the gel coat ended up being just enough extra thickness to keep it from sliding in. That's what I get for trying to do the right thing. I did not want to screw into any stringers. As I've come to learn, if something doesn't go wrong, you probably didn't do much. As least that the case for me. I was still able to get the screw into the narrowed cleat so other than losing an hour and few layers of skin on my knuckles, all is good.
Put some adhesive back neoprene on the floor and sides. Forgot to get a picture before setting the tank in. You can see the top of one of the strips on the left side. Picked up a 2" wide, 20' strip off amazon for $25. Got the extra length as is seem really useful and will come in handy for a yet to be determined use.
Closed up the tank and put some PB in the joint. Tried to just fill the gap without having it go to deep. If I do have to remove that cover in the future, I'm hoping to only have to cut down the seams and back out the screws. Hopefully I'll never find out.
bakerjw
I remember the day of "The deck is in place!"
I also remember the day of "Is that a soft spot?"
This time it is Nidacore and not plywood.
Pmt133
I think I drilled... 44 holes? There were 14 on each side of the floor (7 hull to outer stringer, 7 outer stringer to main stringer) for a total of 28. 6 under the fuel tank. 3 under the bow/cabin floor. 4 under the 2 outside under V berth compartments and 4 in the forward berth compartment...
The deck and outside parts of the berth were all connected with no bulkheads so that was just pour plug the hole and repeat. The in cabin work sucked.
beta
Glassed the deck with 2 layers of CSM. That was a sticky mess for sure. There are a couple of spots I need to sand down but overall pleased with the result. Surprise, surprise... I ended up using more resin than I expected. I only have about 3/4 of a gallon left. Don't think that's quite enough to finish all the floor mounts for the seat pedestals, batteries, hydro pump, etc and reattach the U shaped piece in the front.
On the good news side, I dry fitted the U shaped fiberglass piece in the front that I had to cut out to access the deck. There was a layer of carpet between that piece and the old deck (why????). I was concerned I would have to create some kind of spacer but it fit perfectly just resting on the deck. One less thing to fiddle with.
beta
Need some advice on how to address a number of "chips" on the outer hull. There are 15-20 of these in various places. The picture is one of the larger ones and is fingernail size. Many of them are half this size. The damage appears to only be the surface layer. What's the best way to fix these?
MikeSchinlaub
Depends how much time and money you want to put into it.
Best way would be grind, glass, bodywork, and spray.
2nd is to just use filler.
3rd option would be to thicken the gel and use that as the filler.
You very likely won't get a good match on the gel.
Pmt133
This is a big if... but if you want and they have the right color... I have used the patch paste from spectrum color on a few boats. It is a pre thickened gelcoat/repair paste. The color match is about undetectable every time I have used it.
There is no guarantee they have your color though. Just a suggestion.
Pmt133
They likely have it, but the issue is the sun fade and oxidation over the past 30 years.
True. I did use it on a friend's 98 and it was spot on... but that hull was well taken care of over the last 30 years. As good as my 4 winns is, I'd take my chances at a color match vs buying the paste. Was a suggestion is all.
