1998 9.9 2 stroke mercury troubles
Ian045
Okay people I’m back again unfortunately, so now I’ve got a brand new carb, fuel filter, and fuel connector. I’m still have extreme trouble getting it to start, again only getting it to run at full throttle. I’ve tried factory carb settings I seen on a video on YouTube and I felt like it wanted to start in neutral but I couldn’t get it to, I tried turning my cam all the way up to get more throttle in neutral. Just trying to get some new ideas and figure something out, thank you.
airshot
" new" carb... Factory or Chinese copy ? Factory specs come from a factory service manual, not youtube. If compression is up to specs and spark meets factory specs, you have a fuel issue. Is the carb getting the fuel from the tank and hose ? Many things could be the problem, throwing parts at it won't solve anything. Tests need done to find the problem or we are all just guessing.
Ian045
Is the carb base gasket on correctly?
I believe so, all the holes lined up for the passageways
It’s is a Factory carb, the guy on YouTube went over the factory specs from the manual (I looked them up to be sure) how do I go about checking compression? And the bulb on my tank will stay tight and I can see the fuel in the filter.
airshot
Get an engine compression tester, if you plan on working on engines you will need one so get a good one. Check fuel flow from the fuel pump. The carb settings are a starting point, once the engine is running, final fine tuning needs to be done while under way in the water. Get a spark tester, they are cheap and be sure the spark will jump a quarter inch gap. Glad to see you confirmed the adjustments from the manual. Post your test results when you get them.
