ShoalSurvivor
- Joined
- Aug 1, 2012
- 329
2 intermittent issues, at this stage, after engine removal and reinstall. Goal today was to fire her up and hopefully adjust idle/timing.
What keeps happening (Twice, this self corrected after about 45 minutes and I was able to try again. )
1) Gauge cluster loses power
2) bypassing oil pressure switch to test fuel pump fails
the details:
- I undressed the engine after replacing seals and oil pan; new filter and oil, and refinished the block.
- I disturbed the balancer while the distributor was out, so I have reset to 8ºBTDC after pressure on cylinders 1, and set distributor to cylinder 1.
- checked all connections on starter. Red and Orange circuit complete
- check alternator - Orange circuit complete
- ground from battery to flywheel cover is good (starboard), grounds (through engine) to flywheel cover (port) to wire harness (3 wires) and transom bracket are all good.
- 50Amp fuse - hot on both sides
- Starter solenoid: hot on red side, not on yellow!
- trim pump working, but thats on a dedicated circuit.
When the gauges are on, the starter kicks, engine cranks, but she wouldn't start. Sounded like lack of fuel, so I check for fuel in the carb and found none.
then I jumped the oil switch with ignition switch on, just to make sure the fuel pump was working. it was. reconnected the oil switch, and tried to start, and noticed the gauges were out again, and now the fuel pump bypass isn't working either.
Seems like there is a fuse blowing (and resetting itself) (not the 50Amp) to the gauges and other component, but the starter, alternator and red port of solenoid all remain powered when the other stuff goes.
Hoping for some clues or steps to take. Thanks.
the details:
