4.3 electrical issues (intermittent is a nasty word!)
ShoalSurvivor
2 intermittent issues, at this stage, after engine removal and reinstall. Goal today was to fire her up and hopefully adjust idle/timing.
What keeps happening (Twice, this self corrected after about 45 minutes and I was able to try again. )
1) Gauge cluster loses power
2) bypassing oil pressure switch to test fuel pump fails
the details:
- I undressed the engine after replacing seals and oil pan; new filter and oil, and refinished the block.
- I disturbed the balancer while the distributor was out, so I have reset to 8ºBTDC after pressure on cylinders 1, and set distributor to cylinder 1.
- checked all connections on starter. Red and Orange circuit complete
- check alternator - Orange circuit complete
- ground from battery to flywheel cover is good (starboard), grounds (through engine) to flywheel cover (port) to wire harness (3 wires) and transom bracket are all good.
- 50Amp fuse - hot on both sides
- Starter solenoid: hot on red side, not on yellow!
- trim pump working, but thats on a dedicated circuit.
When the gauges are on, the starter kicks, engine cranks, but she wouldn't start. Sounded like lack of fuel, so I check for fuel in the carb and found none.
then I jumped the oil switch with ignition switch on, just to make sure the fuel pump was working. it was. reconnected the oil switch, and tried to start, and noticed the gauges were out again, and now the fuel pump bypass isn't working either.
Seems like there is a fuse blowing (and resetting itself) (not the 50Amp) to the gauges and other component, but the starter, alternator and red port of solenoid all remain powered when the other stuff goes.
Hoping for some clues or steps to take. Thanks.
Fun Times
What year engine model? Serial number handy.
Decent chance you have a bad connection at the Main wire harness 10 pin cannon plug at the engine… With the key on wiggle the wire wire harness and watch the gauges. See if they turn on and off.
If not, leave key on and start carefully wiggling all wires at engine, ignition key switch and wires under the dash make sure the lanyard switch is in the up/on position by physically touching it, etc.
ShoalSurvivor
2004 'ish 4.3 with Reman engine. Have been told it's:
MerCruiser 4.3L (Gen+) (4Barrel) Reman
No serial number.
I did disconnect the connon plug (as well as everything else). Will try the wiggle and dance test now. Thanks.
I tested the female side if the Cannon and found only one port was hot (7, it think). I was trying to figure out where the gauge power originates from the block.
ShoalSurvivor
More detail:
solenoid jump test kicked starter
getting power and ground to entire console cluster including ignition
verified starter connections, again
fuel bypass still not working. I assume that should fire when oil switch jumped and key on, like it used to, but not now.
wiggled and jiggled but no change.
i will check power at starter from ignition when I can get help.
I sanded a cleaned all grounds. Tested bolts and the ground seems solid
thanks.
ShoalSurvivor
also, will pull console and test ignition switch.
Interesting. Ignition switch continuity passed for both accessory and ignition position. Switch is good.
i pulled the red/yellow ignition wire from the starter solenoid and tested 12v power to switch. Failed. Checked fuse and it was blown. Replaced fuse, now working as expected
checked red/yellow ignition wire at solenoid with ignition switch and it passed.
removed oil pressure switch and jumped it. Fuel pump runs as expected.
pulled jumper and plugged oil pressure switch in and it immediately blew the ignition fuse.
I could probably run through a box of fuses trying to figure this out, it appears that plugging the oil pressure switch is blowing the 10A ignition fuse. does this indicate anything obvious?
ShoalSurvivor
I tested and there is no continuity between the leads in the switch side of the oil pressure switch, so I’m confused at how plugging it in would blow the fuse. Also, I blew the fuse again when measuring the voltage at the oil pressure gauge (between the purple and ground) with a multimeter.
im going to disconnect all purple wires and reconnect them one at a time to see if i can isolate a short.
ShoalSurvivor
Thanks for the diagrams and help!
I just verified the starter wiring and it looks correct. I will disconnect the purple from the starter just to make sure it wasn't touching the red/orange wires. I will also verify the alternator connection- maybe I swapped the purple and red wires, but I was careful to connect purple to EXC. (I did also replace the alternator during the work - could it be bad)? It ran fine before the work, and nothing was changed in the console. Coil is a year old.
I took a photo of both engine ground bolts and all the wires that were connected originally, and have triple checked that they are replaced accurately.
It does appear to be an ignition circuit short somewhere, so I will disconnect and isolate it all before attempting to start it again.
just to verify - If purple is the ignition switch powered 12v circuit, shouldn't the circuit test lamp turn on to show that it's hot when tested against the battery ground? I read somewhere that there should be NO CONTINUITY between purple and ground... Is the coil or something else involved that makes the ignition NOT a normal +/- circuit? Don't all the gauges and fuel pump need the ignition 12v. and the ground to work? Could testing ignition wires against the ground trip the fuse?
ShoalSurvivor
I do not have the starter fuse installed. Should I be adding it now or was it not used in some models?
MERCURY OEM FUSE ASSY-90 AMP | 79023A93​
Fun Times
Possibly depends on the original year of the boat/original engine year as the 90 amp fuse didn't really get started until 1997/98 model year/s though some started a yearish earlier and some even had them in the 80's... So just depends but if the 04ish reman engine model was fully dressed with the wiring harness from new then the fuse ought to had been there as item number 7, https://www.mercruiserparts.com/bam/subassemblydetail/42351709/28186594
Over the years of that model year range there where either the orange or even the Purple / yellow wires coming of the back of the alternator were chafing against engine brackets so check over the wires for open cuts really closely as maybe something is touching now.
If possible, post a photo of the overall engine to see what it looks like.
ShoalSurvivor
Update on tests:
- Retested ignition switch with key wiggle. No change. continuity between connections only during key on and start. Tested with and without wires attached.
- verified purple on alternator connected to EXC
- sanded and reattached all starter wires, verifying no grounding of wires
- Verified that both unattached eyelet grounds (from harness by solenoid and near electric choke) are grounded, and from other thread, not used. (ref: https://forums.iboats.com/threads/4-3-wiring-questions-reinstalling-engine.781003/#post-6010123)
update on isolation tests:
(all with battery disconnected, ignition switch on and off)
- disconnected ALL engine ignition connections
- tested continuity of all engine grounds at flywheel cover, alternator, transom bracket, coil, electric choke, fuel pump, starter solenoid - all continuous
- tested each ignition wire (electric choke, starter, alternator, coil fuel pump, oil pressure sensor) and they ALL reported 45 ohms.
- disconnected (and reconnected individually) each ground to harness, transom, and console at port block flywheel cover. no change to 45ohms readings.
- reattached all grounds.
- Disconnected cannon - ALL aft ignition wires report no continuity to ground.
- reconnected cannon - ALL aft ignition wire report 45ohms to ground.
On block side of cannon, I get ground continuity with pin 1 (ground) and block and no continuity between pin5 (purple)and block.
On the console side of canon (male pins), I get continuity between pin1 (ground) and block, and 45 ohms from pin 5 (purple) of the cannon
Seems to me that I have a short somewhere in my console, and the ohms are traveling back through the ignition wire of the cannon.
next step, I think, is to isolate the console wiring and see of I can find that short- which, has likely been there for a while, since nothing was changed there during recent work.
Some pics (front view is from a couple years ago), rest are today.Screenshot 2026-04-01 at 3.40.47 PM.pngScreenshot 2026-04-01 at 3.40.54 PM.pngScreenshot 2026-04-01 at 3.41.00 PM.pngScreenshot 2026-04-01 at 3.41.22 PM.png
