- Joined
- Jul 18, 2011
- 19,393
Guess I'll have to take you word for it. Being 2X the force than I don't see how the Crap --- arrel stays together going from a SSX 30 to a 280 OSX. I have no stringer extra anything inside the boat. Sure my 280 only has a 25.5 ft hull
Than we can compare the Formula 310 sterndrive or OB, the interior hull is the same less the holes going to OB
Here is the difference in those 2 boats (Formula 310 I/O vs OB)
The outboard version has the hull extended at the full height of the transom and distributes the load to the outer areas of the hull. (actually a clever design)
The I/O version does not have the hull extended and is transferring the forces more directly to the stringers. So, if you took the I/O version and converted it to OB's you would have to/want to add the support braces, as is the case with most conversions.
