Merc 250 Verado Fuel increase
Checked fuse and it's good
Run test with just starboard running and it does get louder, it's just not as quite as port motor. Also did tested the ASC with Techmate and it passed, so no real problem. Will go back down in a bit to see if it actually reads the AEV or ASC parameter
Did find another Fault 4602 which I think is the low voltage
Took a bunch of pics to send to Odyssey to find out if they can determine did my $200 charger damage $900 (edit) $1713 worth of Bats
Pmt133
I'm not incredibly familiar with the terminology nor am I sure I am remembering correctly but... Last year weren't you seeing a difference on the DataStream with the exhaust open/closed at wide open or something to that effect? (I would expect that to make a difference normally, but just reading through I thought I remembered that happening) I don't suspect that is your issue, just found it interesting if I was remembering correctly that you seem to be seeing a sound difference between the two engines with it open/closed as well now....
I'm not remembering anything with a datastream issue, but being old and suffering from CRS doesn't help :LOL:
The motors are said to have no effect on performance with the exhaust open or closed
Pmt133
That's what I'm remembering. Drop in load or commanded load or something that seemed to contradict the "no performance change" lol. Not a data stream issue.
Most likely a nothing burger but reading through this is thought I may have remembered something critical when in fact, I just remembered something. :LOL:
Oh that's demand liner, demand, and demand Guardian
I will use those readings to find out if my change it props is a good or bad thing. I do like the way the Mirage props bit better backing up over the Rev4
@muc looked for AEV and ASC and found neither. All I'm seeing is exhaust on/off and test kind of things
