Which kicker mount to install?
rogerlamb123
On my 1998 Century Walkaround 2100 I want to add a 4 stroke kicker to go along with the Yamaha 150. Given the style of the swim platform/stern I am trying to figure out the best kicker mount and how installed. Looking for advice from someone who has done this.
Thx, Roger
Need to fabricate an adapter so that bracket mounts to a flat surface.
rolmops
And don't forget to make sure that you have some serious backing under the flat surface to prevent the kicker from damaging that surface.
rogerlamb123
Are you saying to add a plate between the mount and the swim platform? The concern I have is that there is no way to get access to the underside of the swim platform. Given that how would I bolt the bracket to the swim platform?
rolmops
If there really is no access, which I doubt, you might want to consider an alternative option like getting a Yamaha main engine that has the trolling option. I heard that there is a setting on the 6 cylinder Yamahas that will shut off 4 cilinders and you can troll to even less than 3 mph on the remaining 2 cylinders.
airshot
While not easy, some how you need to access the underside of that flat surface as that would be the easiest area to attach a mount. One could be adapted to the actual stern, but access to that would be even more dificult. Perhaps contact the boat mtg and see what recomendations they might have. Glass boats need some type of backing plate to spread the load so the fiberglass doesn't eventually crack. You have your work cutout for this project, good luck.
airshot
You will need to access the inside area of your transom where you will be mounting whatever bracket you will use for your trolling motor. Some how some backing support will be needed. No way around it if you want it properly done.
dingbat
Its for both trolling and backup
Not worth the extra expense for trolling use.
Back up only works on lakes and only if you run separate fuel supplies to prevent cross contamination of your fuel supply
rogerlamb123
If I cant get underneath the stern to provide a support what do you think about a mount like this where it also mounts to the rear of the platform?
airshot
I would not trust just bolts and nuts as they could pull thru the fiberglass. Some type of backing plate will still be highly recomended !
airshot
Bottom line is....I don't think anyone would recommend just screwing into the fiberglass, no matter how many screws you put in. Without some form of backing plate or large fender washers at minimum you definitely need to access the inside surface of where the mount will attach.
rogerlamb123
I understand. I'll see if there is some way to access underneath. Thx.
