1972 johnson 25 hp ignition points
Chrisham
I GOT A NEW SET OF POINTS AND CONDENSERS FOR THIS MOTOR.SIERRA 18-5002.NO MATER WHAT I DO I CANT GET THEM ADJUSTED TO CLOSER THAN O25.anybody had this issue before.Should the point wiper be adjacent to the flywheel key or top on the flywheel taper.
Is the cam screw bottomed out?-----And you can use the timing marks on the flywheel ( yes there are two ) and the vertical lines on the magplate to set points with a meter.----Gets you the STRONGEST spark.----Tutorials on U-TUBE for this " best method " that I have used since about 1968 !
Crosbyman
the actual gap isn't all that critical. the timing of the openning is critical
see video. .020 is a ballpark using the high point of the cam
just adjust the gap openning " time" per video
Chrisham
I watched videos all I could find.Mine does not have the access holes in the flywheel to adjust
I EVEN BOUGHT A TIMING TOOL.WHEN I TRY TO ADJUST THEM I GET 0.00 across the meter.I think it should read ol for open link.I can adjust them and see the points open and still reads 0.00.I am touching the points on the metal part that has the moving contact and across the insulator on the screw side.It blows my mind.I wander if the multi meter is bad it's a Walmart everstart.Setting is the upside down horseshoe which is ohms.Im going get my brother in law over who is an electrician to show me what I'm doing wrong
Chrisham
I d
I don't think think the cam screw is bottomed out it turns easy and I can see them open and close
Sit back / relax and study videos.----This is EASY.-----Showed my technique using the marks on the flywheel to a friend.----He said ----" wow , this is magic "----Not sure why you mentioned hole in the flywheel !----Do you understand that you are setting the points to open at the correct instant to TIME THE MAGNETO?----Timing relative to piston in the cylinder in automatic !!
Crosbyman
did you remove all wires from the point screw because your primary coil wire goes to ground and a bad condenser could be shorted to ground . test only from the screw side and frame ground .......if the points visually open at the high point of the cam you will see infinity (ol)
millions of OB work that way and yours is no exception.
did you follow the video posted above . I doubt your meter is bad ! just pretest by shorting both probes to get 0 ohms and infinity when not touching
