Inherited boat, how bad is this?
Hey guys! First time poster, first time boat owner, and I could use some help.
Earlier this year I inherited a 1984 Baja Force 220 from my Grandparents. Sadly, Grandpa has severe dementia and they are moving to care for him. This boat was his pride and joy. It spent the last 20 years in his garage while he worked on it to make it more comfortable for my Grandma. He wanted to take her camping for a week on it, so he was adding things like a fridge, hot water, toilet, microwave, and AC to the cabin. Sadly, he never got it completed before his dementia prevented him from accomplishing this.
Since some of the work wasn't done great on account of the dementia, I've spent the last few weeks going through it, trying to figure out what is good and what is not.
THE GOOD:
The motor (Mercruiser 260) fired right up with a new battery, oil change, and cylinder fogging.
Trailer is in good shape.
THE BAD:
It looks like he cut a section of stringers out. I'm not sure if they were rotted, or if he needed room and just never got back to it. I pulled up the center deck board and removed the fuel tank to inspect the rest of them, and I'm not sure I like what I see. I'm new to boats, so I could use some advice.
Missing Stringer
Missing Stringer
Missing Stringer
Missing Stringer
Missing Stringer
Missing Stringer
Screw driver punched through rotted wood
Where gas tank used to be. Worried about dark wood near bottom of stringer.
Cross beam near the engine. Completely loose and so rotted that a screw driver punched through it.
Inside the cabin, before I tore it all apart. Dog likes the boat
Parked in the driveway first night after picking it up.
Daydreaming!
Daydreaming!
When I got the boat, I was under the impression that it was in generally good condition, with the exception of Grandpa's new additions (we weren't sure of the quality of his work in his old age). I was prepared to undertake a little bit of a project to get on the water. But now I am fearing it needs a total overhaul. I'm interested in having a boat and doing some tinkering, I'm not sure I'm interested in a total overhaul. I've painted cars and done some engine swaps, I'm handy, capable and hard work doesn't scare me. I'm just not sure this is where I want to invest my time right now.
How bad is this?
Is it worth fixing?
What is the ballpark estimate of having this repaired?
Doing it myself?
How involved is it?
Do I have to take the whole deck up to do it?
If it's not worth fixing, how much is it worth as-is?
MikeSchinlaub
Your pictures didn't work for some reason. Iboats has a file size limit, so try reducing the size/quality of the pictures.
From the descriptions though, you're looking at a total structural rebuild. The stringers are a total loss, transom will be too, and the floor will have to come out to do the stringers. That's a huge job. Months of doing it after work every day, grinding fiberglass and getting the dust everywhere, resin fumes, and thousands in materials.
Welcome
Repairing hulls get expensive real quick. Most are not financially worth fixing, but the ones that do get fixed are because it means something to the person doing the work.
So you need to decide do you want to take it on? If you do we'll be hear to help
Huh, must be something on my end. Pictures in other threads are showing fine.
Does it work for you now? Or still nothing?
Welcome
I might be willing to do the work, but I'm trying to figure out how involved it is and what it will cost me. The boat was grandpa's pride and joy, and we have photo's of all the grandkids on it with him. It would be really awesome to keep around and I know it would warm his heart to see it on the water again.
A project that costs me only $1000 and a week worth of work may be worth it. Something that is $10,000 and MONTHS is likely not haha. I'm trying to find out what ballpark this lands in.
redneck joe
Closer to the 10k than the 1k. Prob need to spend a week or two digging in a bit more to see what you got, incliding the transom.
It will cost more than 1K, depending on the rot I would estimate 3K and that is knowing the motor and drive only need maintenance.
I would estimate 2 months minimum and that means your a quick study with fiber glass work
Sheesh... is it worth anything in its current condition if I wanted to sell it?
airshot
While it looks cool, your best bet is to part it out if your not gonna put in the time and money. Keep in mind, most fiberglass boats were designed for a 25 year life span, your well past that, so ......your call !
^^^ Agree with airshot, part out what you can. The Merc 260 isn't worth that much except to someone which can not afford to rebuild their own motor, same with the drive. The trailer looks in good shape, but looks can be deceiving
Ask around on the Baja facebook page, might find someone looking for that model
MikeSchinlaub
Nope. No big deal, I've seen enough mulched stringers to pretty much know what you're looking at.
I would ballpark it somewhere closer to 5k and 6 months, assuming you have a full time job and other life responsibilities, plus the inevitable needing a break from it. Needing to lift the cap depends on how it fits on the inside. If everything that touches the floor is removable from the sides then no, but if the sides come all the way to the floor and are part of the cap then probably.
Under the floor, and between all the stringers the voids are full of (likely saturated) flotation foam. You'll have to get that out as well, and replace it if you decide to rebuild.
tpenfield
Yes, closer to $10K than $1K and closer to years than weeks. It is hard to tell from the pictures of the cuddy cabin if the stringers were removed or just exposed.
One thing you need to factor in is knowledge, which you are starting out at a fairly low level.. This will increase the time involved as you will need to learn about boat restoration.
The forums have stickies that have most of the answers
the hull restoration forum sticky that will help the most https://forums.iboats.com/threads/how-tos-and-other-great-information.283508/
start by reading link 14 in its entirety, then go on to 15, 18, 2, 3, 4a, and 4b
regarding the budget. if your budget is $1000 and 1 week. scrap the boat, sell the trailer.
a realistic budget if you have all the tools already is $8-10k.
the tools and PPE will be close to $1k alone
HoosierHacker89
Just a stranger on the internet, but I think you've got a motor and a trailer to sell. That's about it. Best to scrap the boat unfortunately.
