Scott06
- Joined
- Apr 20, 2014
- 7,558
friggin auto correct...Why would you replace the ignition system if it’s working? The atB is a great system until the ignition module needs to be replaced $$$. Then typical replacement is a delco est. this isn’t any better except module rEllacement cost. Both are OEM quality systems.
I meant the Merc TB (thunderbolt) is a great system, Merc just screws the owner by NLA or insane ignition module prices... so when the module dies a actual Delco Est (not cheap knock offs) is a good relatively drop in replacement.
Yes the trigger sensor is not a bad replacement or keep one in the boat. Also keep a cap and rotor. I had to chisel my rotor off when I replaced it, so likely if you have to replace the trigger likely you will waste the rotorThanks everyone, I will keep everything intact as of right now. I will still order the 3 wire trigger, cap, rotor to keep on the boat as they are easy enough to change on the water if needed. I was hoping to go out again this weekend but the weather is not looking to great.
