Water or oil in Cylinders
ricodudink
Hello everyone,
I recently rebuilt a Mercruiser 140 and have been running it for a short period. After about 20 minutes of running time, I inspected all cylinders and I have the impression that water may have entered the cylinders.
I would really appreciate your feedback on whether this actually looks like water intrusion and if this is considered a serious issue.
It appears to be worse in cylinder 4 compared to cylinder 1, but the engine is still running and operating perfectly smoothly.
Before the first startup, some water did enter the exhaust, which I removed as much as possible. I do not believe this is the cause, but I would like to hear your thoughts and experiences on this situation.
Any advice would be greatly appreciated.
WhatsApp Image 2026-06-03 at 19.47.19.jpegWhatsApp Image 2026-06-03 at 19.47.18 (1).jpegWhatsApp Image 2026-06-03 at 19.47.19 (1).jpegWhatsApp Image 2026-06-03 at 19.47.18.jpeg
Scott06
Hello everyone,
View attachment 416651View attachment 416653View attachment 416652View attachment 416654
normally if you have water entering the cylinder you will have no carbon in the cylinder or on the spark plug as it will steam clean it so to speak.
If you think it is in #4 this could be from the exhaust manifold to elbow joint or a bad exhaust. after running it let it sit a bit take the plugs out and spin it over see if water comes out of the cylinders
How did the water get in the first time? is the oil milky ?
ricodudink
The water likely got in because I replaced the elbow riser and there was still some water trapped inside it. However, I do not think this could be the cause of the issue I am seeing.
Regarding the carbon deposits: after about 15 minutes of running, there was almost no carbon on cylinder 4 and a small amount on cylinder 1. It looks like any possible water presence becomes more noticeable the further back the cylinders are in the engine.
I am considering running the engine for another 5 minutes, then draining it. After that, I plan to remove the intake manifold and inspect the exhaust ports to see if there is any water present there.
I also checked the oil and did not find any significant signs of water contamination, only a normal amount of moisture.
ricodudink
I am currently pressure testing it at 15 psi. Over 15 minutes, I lost about 12 mbar (approximately 0.17 psi). I suspect this is due to the rubber hoses used during the test. Do you think this is within specification?
Is it possible that if the exhaust is cracked, the cylinders fill with water slowly?
Scott06
that is fine for a pressure test. no issue
Yes it is possible the exhaust is cracked. Normally folks do a test filling the manifold with acetone and see if it weeps into the exhaust side as it wicks through cracks more easily than water.
Can also get sucked in if elbow is rotted out. If it si s salt water boat about every 5 years you need to replace manifold and riser, fresh water unless freeze damaged they typically last life of the boat
ricodudink
I removed the manifold after your message and noticed that all the exhaust ports are completely dry. What surprised me is that all the intake ports are wet. I have no idea how that's possible.
Is that something you would normally see with a cracked exhaust manifold?
I replaced the elbow/riser about two weeks ago, but I didn't replace the exhaust manifold because they're not available where I live.
Scott06
intake and exhaust on your engine are the same manifold. So could crack into the intake just same same as exhaust, unless the intake wetness was gas. If it was water you found your leak.
Ayuh,...... What, exactly, did you do to "rebuild" this motor,..??
I ask, because it don't look like a rebuilt motor in yer pictures,....
ricodudink
When I rebuilt the engine, I didn’t spend any time on the exterior, and I haven’t replaced the starter or the alternator yet. However, everything inside the engine is new. The rebuild was professionally machined and assembled by a machine shop.
Ayuh,..... I assume they pressure tested the head, 'n block,..??
